Profibus communication problem between Beckhoff IPC and Siemens PLC
najafabadi
Aug 2006
Tehran
Hi everybody,
An IPC connected to a Siemens PLC as a slave module. When I restart the PLC while IPC running then PLC can't find the IPC node on the Profibus network. I should also explain that if before restarting I disable the IPC node in Profibus hardware configuration by using the SFC12 and then restart the PLC and then enable the IPC Profibus node again by using SFC12 in Profibus hardware configuration the PLC can find the IPC easily.
For more information the IPC Profibus node exists as a last module of the bus and some ET200 modules also exist on the bus.
I use Beckhoff IPC with Beckhoff Profibus cards and TwinCAT I/O software for communication to a S7 315 2DP PLC.
Many thanks in advance for your help.
Babak
Dear All, I have a KUKA Palletizer machines having Iconics Genesis SCADA installed on its PC. It remained closed for about 7 to 8 years. We are...
965
Hello guys, I have problems with the Porfibus communication to my regulator Siemens Sipart DR 21and my PLC rockwell 1756-L161. So, for the...
2,106
Hello to all, I have a strange problem with establishing the communication between WinCC HMI station and the rest of Profibus network. We have...
3,883
We are having Siemens s7-400 dcs system, we are using profibus dp communication for dcs & all ABB vfd drives (ACS800). Now we are facing major...
3,177
Hi Guys I have connected 2 s300-314C-DP plc in Profibus. as I am running in test mode, I noticed both can communicate only in lowest bus speed...
3,983
