Profibus communication problem S7-400 & ACS800
vikram7194
Apr 2014
satara
We are having Siemens s7-400 dcs system, we are using profibus dp communication for dcs & all ABB vfd drives (ACS800). Now we are facing major problem that anyone motor get suddenly stopped without any alarm or all motors data lost sometime. we checked n find that on profibus adapter RPBA-01 thre is problem that it continuously goes online-offline.
so pls suggest firm solution for this.
Vikram
Vikram
You'll need to thoroughly check your cabling and grounding installation. Here are some tips from experts:
http://www.procentec.com/faq/profibus/
Kalle
Dear All, I have a KUKA Palletizer machines having Iconics Genesis SCADA installed on its PC. It remained closed for about 7 to 8 years. We are...
963
Hello guys, I have problems with the Porfibus communication to my regulator Siemens Sipart DR 21and my PLC rockwell 1756-L161. So, for the...
2,103
Hello to all, I have a strange problem with establishing the communication between WinCC HMI station and the rest of Profibus network. We have...
3,872
Hi Guys I have connected 2 s300-314C-DP plc in Profibus. as I am running in test mode, I noticed both can communicate only in lowest bus speed...
3,972
Hi everybody, An IPC connected to a Siemens PLC as a slave module. When I restart the PLC while IPC running then PLC can't find the IPC node on...
9,150
