Performance comparission between the AB FlexLogix and CompacLogix PLCs
nqn827
Aug 2007
Livermore, CA
Do you know if there is any article that lists/describes the performance between the Allen-Bradley FlexLogix and CompactLogix PLCs? What I'm looking for is, given a same Logix5000 routine, which PLC will be faster and by how much? The pro/con of each of them.
TIA
I don't think there is any measureable difference in processing speed between Logix platform CPU's running the same code. The key difference is going to be in the sheer size of the program, number of tasks, communications connections and CPU memory. The attached document is from the inside cover of the FlexLogix Selection Guide (1794-SG001) and contrasts features of all Logix CPU's. Pros/cons: given the 2 choices you listed, it would simply come down to price (CompactLogix will be lower cost) and if motion control beyond stepper control is required (both platforms will do stepper control. If servo control is required, you will need the new CompactLogix 1768-L43 CPU, power supply, comms modules, and the traditional 1769 Compact I/O.
Unless you have a valid reason to stay Flexlogix, you should select CompactLogix platform.
You will not see performace difference, but selection variety and support in future versions makes CompactLogix the only choice in your case.
Greg Dake said:
Are they going to continue support for Flex I/O modules and their 1794 communication interface?
Greg
Yes, all 1794 products still available.New 1794-AENT/B coming out soon.
Controller will be in production as well, but no support in newer versions because of memory limitations.
Hi All I have just configured a new 2711P-T19C22DP - it needed firmware V12 which I (eventually) got installed, and got my application running. I...
212
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
362
Hello all, I know in the past it's been the case that we wanted to limit the total number of GSV calls per scan of the PLC. Is that still the...
677
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
829
really strange issue. The panelview(2711p-T10C22D9P) will try to load an application and get stuck on "Starting Alarms". If I reboot the...
1,505
