plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 18th, 2009, 01:25 AM   #1
naeemmsc
Pakistan
naeemmsc is offline
Pencil What the Main difference between PLC and DCS
I want to know what is the main difference between PLC and DCS.if PLC Perform every task why we use DCS.Plesae can some one tell me about DCS5000 literature web sites.
Old May 18th, 2009, 02:31 AM   #2
sumanthb4u
India
sumanthb4u is offline
Quote:
DCS contain both SCADA & logic programming in it.
Old May 18th, 2009, 06:17 AM   #3
tomalbright
United States
tomalbright is offline
A PLC system CAN work by itself. However, if it relies on, or supplies signals to other components to operate, then it MAY be called a DCS. It's the idea of "distribution"; many components, or many components working together? The term of "DCS" is pretty vague, to be honest.
__________________
"We really don't care how you program your PLC, just don't blow yourself up!"
www.GeekQuake.com Also on Facebook!
Old May 18th, 2009, 06:25 AM   #4
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
In manufacturing you make either 'things' or 'stuff'. Traditionally, PLCs have been mostly involved in the manufacture of things and DCS have been mostly involved in the maufacture of stuff.
The dividing line between the two gets less distinct with each new generation of controllers.
Old May 18th, 2009, 08:37 AM   #5
danw
United States
danw is offline
danw's Avatar
DCS is always tag based and server based.
PLC's are memory based.
Dan
Old May 18th, 2009, 10:38 AM   #6
FrancisL
United Kingdom
FrancisL is offline
The size of the suppliers expense accounts
DCS's are bigger
__________________
Keeping it Simple takes thinking time.
Old May 18th, 2009, 11:37 AM   #7
shooter
Netherlands
shooter is offline
shooter's Avatar
PLC means programmable logic circuit
in general it means a sophistacted relay box that can be programmed with a ladder program. So simple on/off in a line and some timers/counters.
DCS means digital control system Almost same , however programming is done in basic, C, pascal. The in and outputs are not standard
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old May 18th, 2009, 11:49 AM   #8
FrancisL
United Kingdom
FrancisL is offline
PLC means Programmable Logic CONTROLLER
DCS -Distributed Control System
And we do not use Pascal or C in Control
__________________
Old May 18th, 2009, 12:41 PM   #9
Tom Jenkins
United States
Tom Jenkins is offline
Tom Jenkins's Avatar
Historically DCS developed in the process industries and were the result of adding capabilities and communications to single loop PID controllers and using mini-computers for HMI functions. Many DCS systems use proprietary communications protocols and have proprietary programming languages, although most modern systems are more open and flexible.
PLCs grew out of component and product manufacuring as relay replacement systems. Most program in Ladder Logic but modern units have a wede variety of programming languages, analog I/O capabilities, math functins, and communications.
Old May 18th, 2009, 12:56 PM   #10
PLCMentor
United States
PLCMentor is offline
PLCMentor's Avatar
You have hit upon a discussion that has been raging in the industry for 20-30 years. Over the years, the two have come together to the point that there is not a whole lot of difference. The biggest difference is probably in their origins.
PLC's originated with discrete control. Designed to replace large amounts of relays. This also is the reason for PLC's dominant programming language being ladder logic. The target audience was electrical engineers and electricians. Ladder logic is well suited to the core training of both disciplines so EE's and electricians can understand ladder programs due to their similarity to electrical ladder diagrams. Over the years the functionality required by advanced ladder programs has somewhat negated this advantage. Many of the commands available are in no way comparable to electrical components. PLC's have also expanded to include structured text programming, function block programming and step programming. Analog I/O and capabilities have been developed to cover a full spectrum of possibilities. SCADA systems have developed to be paired with PLC's to allow full visualization and data manipulation.
DCS's originated to fill in with analog control. Developed for process industries, they were designed around process engineers - usually chemical engineers. They were designed for large systems and generally were programmed with some form of high level language or function block programming. They now have ladder and discrete functionality and even tend to look more like the PLC's. DCS's tend to integrate the visualization and data manipulation better than their PLC counterparts as their configuration is usually a single system designed to work as a whole; however, the PLC manufacturers have made strides into duplicating this capability. The costs of DCS systems are generally higher than comparable PLC systems.
I really dont see a lot of difference today between the two platforms. EE's tend to gravitate toward the PLC's still and Chem E's tend to still gravitate towards the DCS's. The PLC manufacturers are constantly trying to break the image of small system and/or discrete machine control even after all these years. Many of them have gone to calling their upper end controllers PAC's or programmable automation controllers. Change the name lose the stigma.
__________________
Russell White, P.E.
Automation Technologies, Inc.
PLCMentor.com
Old May 18th, 2009, 05:01 PM   #11
plc noob
United States
plc noob is offline
plc noob's Avatar
Smile
And thus we have the PAC http://en.wikipedia.org/wiki/Program...ion_controller
Higher level models of contrologix plc's are considered a PAC an example is here http://www.ab.com/programmablecontrol/pac/
Add a client / server hmi system and maybe dta collection such as a historian and you have what in the olden days would be termed a DCS or SCADA
Old May 19th, 2009, 06:34 AM   #12
Yuryas
Russian Federation
Yuryas is offline
An Example with Siemens:
Simatic PCS 7 is DCS
As a rule it is based on Simatic 414 416 PLCs.
Old May 19th, 2009, 06:45 AM   #13
FrancisL
United Kingdom
FrancisL is offline
A more focused question is to ask What are the Main differences between PLC's and DCS controllers?
By which I mean let's not look at the networking, HMI etc, but just at the controllers themselves.
And here there are still differences that go back to the Discrete origins of PLC's and the continuous origins of DCS's
With a PLC you can code close to the metal, easily setting and responding to individual bits, bytes or words, or even tables of them with confidence that the program will use little memory and execute fast.
This is not the case with the controllers in most DCS's.
__________________
Old May 19th, 2009, 08:17 AM   #14
Andybr
United Kingdom
Andybr is offline
The best definition I ever heard was that if the salesman tries to sell you a chair its a DCS.
My view is that the historical definitions are no longer valid. A Control Logix processor has never been a PLC in the original sense and the PC based modern DCS's are a million miles away from a Rosemount System 3. Selection needs to be based on engineering criteria rather than outdated terminology.
Andybr
Old May 20th, 2009, 04:06 AM   #15
naeemmsc
Pakistan
naeemmsc is offline
Thanks for all those response my question.But one thing is still not cleared that if any task can perform PLC so why we use coslty DCS system Is there any limitations Of PLC that we have to use DCS>Thanks
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
connection between RMS controled by PLC and DCS control room DeltaX LIVE PLC Questions And Answers 0 December 27th, 2008 06:29 AM
Total Fustration - PLC vs DCS jaichains LIVE PLC Questions And Answers 21 November 26th, 2008 11:38 AM
how to exchange the datas between PLC and DCS? jayesh.monpara LIVE PLC Questions And Answers 5 August 11th, 2008 08:33 AM
PLC Integration with DCS sandhya123 LIVE PLC Questions And Answers 1 October 30th, 2007 09:48 AM
