This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Dec 2009
thermocouple relay is their such????
Hello again i've started another project and i have limited inputs and i need to read several kilns with one reader so my question is,,is their a relay made that can or could read thermocouple (j or K )wire through the relay or if anyone knows some sort of way to read several points with one reader im game to any idea thanks in advance..Mer..
#2 |
__________________
#3 |
![]() Join Date: Aug 2005
I have been trying to find some locking thermocouple plugs, still had no luck with that.
However, one supplier I spoke to told me to use any connector I wanted to, as so long as there is no temperature differential across the connector it won't act as a cold junction and affect the measurement significantly in my application. Whether this is true for all temperature ranges I don't know, but I would be tempted to set up a trial using any old relay you like to see if it does actually affect the measurement. |
#4 |
More links
http://www.omega.com/toc_asp/subsect...perature&all=1 http://www.newportus.com/products/acccalib/thmowire.htm
__________________
Mickey If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else. ----- Chinese Proverb |
#5 | |
Didoo!!!!! Thanks
Quote:
#6 | |
I,ll try but !
Quote:
#7 | |
Quote:
The scheme is functionally a de-multiplexor, many inputs to one output. There has to be no temperature difference between (+) & (-) terminals at both input and output. You are practically guaranteed a temporary error if you are handling the connectors and the wire while crimping a connector terminal, you finish, and connect it. Your body heat has transferred to the wire/connector. Drafts or circulating air in a panel can heat/cool some terminals and not others. Any temperature difference between the connection terminals is a direct error at the cold end of the thermocouple. Shielding the connection points from any draft of air, whether cooling or convection heat is a wise idea. The polarity of the thermocouple wires has to match. + has to switch to + - has to switch to - You can be big errors by swapping polarity. The type thermocouple wire has to be identical on both input and output. K to K, J to J, etc. |
#9 |
![]() Join Date: Jul 2007
We use a similar situation here, multiple temp. probes into one analogue input. OEM used a multiplexer card, and this works very well in our situation
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| XIO and XIC... and variations thereof... | Terry Woods | LIVE PLC Questions And Answers | 46 | August 13th, 2010 02:06 AM |
| Choosing relay and PLC output card | Adenitz | LIVE PLC Questions And Answers | 17 | February 19th, 2010 02:57 AM |
| External Relay causes PLC fault | triplewhammy | LIVE PLC Questions And Answers | 39 | January 16th, 2007 10:30 PM |
| Thermocouple readout fluctuations | leitmotif | LIVE PLC Questions And Answers | 18 | March 5th, 2005 08:58 AM |
| The "Imaginary Relay" Problem, Part-1 of 2 | Terry Woods | LIVE PLC Questions And Answers | 8 | December 26th, 2002 05:33 PM |
