0-10v Analog output to control VFD
Hi
As Mickey has pointed out 32760 would be 10.5 volt
Lets try
31200 as the max output to give 10 volt.
Anyone tell me why a card would want to give out 10.5 volts.
Would it be used if the card was set to upscale if somthing was wrong ??
Donnchadh
it is very handy when you have some reserve when calibrating, this way i can make a nice 10 volt signal when the electronics are a bit off.
Click Plc/analog 0-10 v output module/0-10v dimmable led driver. I made a program using multiple drum to create by increment fade in and out led...
1,414
Hi Friends, I have a LVDT for measurement of cylinder stock which output in resistance. How can I connect it to PLC's analog input? If is there...
2,292
Hi guys, I've a field instrument (actuator) using 24V AC, 0-10V. The terminal connection as below: Terminal 1 = 24VAC Terminal 2 = 24VAC Com...
3,954
Hi. I have an application where I going to control a servo motor. The input to servo motor driver card is +-10V. So I have a +-10V output card...
5,634
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
282
