1305 VFD drive
Unregistered
Guest
U
Can anyone explain to me the difference between two wire and three wire control in the 1305 vfd operations?
thanks
2-wire VFD control typically means you are using maintained switches (i.e. Closed=run Open=stop or Closed=run fwd and or run rev Open=stop). 3-wire is more like a traditional hard-wired motor ckt with momentary start/stop pushbuttons.
To be more graphic this is an elementary 3 wire circuit, give it a few seconds, its animated.
I really dont understand how the comm / control works with 1746 l542b w ni4v analog tring to control my motor. 7.7amp (460) max motor = 1725rpm...
2,674
I am looking at a 1305 drive connected to a PLC5 via RIO. The drive is working and I was able to get a functional HIM working on the drive as...
1,862
Hi Everyone, We do have several cabinets with SLC5/03 CPU's and two SCANport modules, each. 5 ports are being used, communicating with 1305 VFDs...
2,495
Hi all. I am currently on a project or updating a panel with a slc 5/04 processor controlling 3 1305 drives via a 1203-sm1 SCAN Port. The company...
2,288
Good afternoon, I have an AB 1305 Frequency Drive with an HIM module on it. Normally, after it runs a part, it says "Stopped +0.00 Hz". What...
2,986
