1395 DC and Drive Executive 5.01
The Plc Kid
Feb 2009
Macon, Georgia
3,233
I am rying to connect to some 1395 drives with drive executive to get parameters as a drive has failed.
I am having zero sucess getting it to communicate using the 1300-ITSSC Series B cable.
There is not much on the rockwell site or the internet in general.
I am in a pickle. Can sommeone give some tips?
Yep it is the 1300-ITSSC Series B cable and that is what I am using. It is a 232 to 422 converter.
I got it working it just took 6 hrs of hammering in different combinations of settings to get it working right with the new version of drive executive and a faster computer.
I have a 500 hp. Drive that has a field loss fault. changed drives, no help. Changed motor, still has field loss fault. put a resistive load on...
4,146
Hi guys, I am facing a peculiar problem a 1395 dc drive, make- alllen bradely. When I issue a jog command to the drive via PLC it works fine ...
1,707
hi guys, I need help to configure 1395 dc drive with plc 5.How do I link the drive parameters to inputs/ ouputs of plc.Pls help!!
1,992
HI, I have studied the manual for this zero speed digital ouput relay contact. P558. The contact is suppost to close when the drive is at zero...
2,641
I am having trouble undestanding what is happening in two of our drives on our ERW strip prep line. The drives are issued start/stop/jog commands...
3,690
