1732E-8IOLM12R Fault Code 16#0010
Tearboss
Aug 2021
Frankfurt a.M.
Hey there, this is my first thread/question, so hello plctalk-community! (y)
I got a modul-error for the 1732E-8IOLM12R from the ArmorBlock I/O Specialty I/O Modules.
Before I start I installed the EDS- and AOP-file.
I set the switches to 999 and use the BootP/DHCP software to give the modul a IPv4-Address and "Disable-BOOTP/DHCP".
After I add the modul in my E/A-Configurations. I set up the name, IP and change in the "Modul Definition" the Series and Revision.
So far so good. I think it is connected but than I get the Fault Code:
16#0010 Mode or state of module does not allow object to perform requested service. You can see it in the attachment, but there it is in german.
I know that problem from the 1734-AENT. There you can solve the problem by set the chassis size. But I don't see any option to set this up in the 1732E-8IOLM12R.
Do you have any experience with that to solve that fault?
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
137
Hey guys, As you remember from a previous post on another topic I am programming a training cell with 5 robots. One of the robots has the above...
1,044
Hey guys I'm programming this training cell as I mentioned in a previous post. Root of this problem is: We installed the above mentioned module on...
2,018
We installed Rockwell ArmorBlock 1732E-OB8M8SR modules, and set the ip addresses. But, in the properties of the module, it is "Owned No" . How can...
18
4,375
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
67
