A-B 1732E-IB16M12DR Configuration issues
saultgeorge
Jul 2015
Detroit
535
Hey guys,
As you remember from a previous post on another topic I am programming a training cell with 5 robots.
One of the robots has the above referenced module on it for sensing part present, clamp position, etc. It’s a FANUC, and the robot guys need the instance, size and configuration info to manually input into the robot software through the teach pendant.
When I added this module to the I/O tree, it doesn’t give me options to do this type of configuration, like a generic Ethernet module for instance.
So do I need to use a generic Ethernet module with the I/P address for the block? Take the block out of the I/O tree? The manual doesn’t say much. The robot guys have the EDS files for the module but to experiment with all the configurations for instance, size, etc. is counterproductive and isn’t working well. Thanks for reading and have a great rest of your week!!
Respectfully,
Hey guys I'm programming this training cell as I mentioned in a previous post. Root of this problem is: We installed the above mentioned module on...
2,017
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
137
Hey there, this is my first thread/question, so hello plctalk-community! :yeah: I got a modul-error for the 1732E-8IOLM12R from the ArmorBlock...
2,356
We installed Rockwell ArmorBlock 1732E-OB8M8SR modules, and set the ip addresses. But, in the properties of the module, it is "Owned No" . How can...
18
4,370
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
60
