1734-IB*S Test Output Status
whiteazz
Dec 2003
epworth, iowa
In the 1734-UM013 appendix A it shows how to monitor a status bit and then use that bit to trigger a message to retrive the error. I can't find a status bit for the test output that could be used to trigger a message to retrive the error for the test output. Does anyone have a idea on where to look, or a simple way to do this without reading the status of each individual test output on every IB8S module.
As far as I rememeber Test Outputs are standard outputs, they don't have built-in diagnostic like safety In/Out have
Answer to question
The status of the test outputs can be monitored in the same fassion as the Pt Status's. When configuring one must configure Pt. Status-Power-Muting-Test Output instead of just Pt. Status, for the Input Status; under Module Definition.
Pt. Status-Power-Muting-Test is only required when you set Test Ouptut as Standard outputs
When you use them exclusively for pulse test, this selection is not required
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,206
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
63
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
628
I am trying to use the 4-20 mA signals from a device whose user manual says that it outputs "isolated 4-20 mA". I only have spare PLC inputs in a...
235
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
353
