1747-UIC vs Serial Card
Big John T
Nov 2006
Poplar Bluff
199
I just installed a serial card in my new computer. It has two ports and they are configured for com1 and com2. My 1747-UIC is on com3. When I try and use the UIC with rslinx I get an error
RsLinx has failed to configure the com port!
The com port may already be in use
Any Ideas?
I'm about to pull my hair out and I got lots of it to pull...
John
If you added the serial card then check Control Panel to see if you have a conflict with ports. Com 1 and 3 use the same IRQ etc and the serial card may be holding it captive.
Was not what I was saying, by default com1 and com3 share resouurces, since you have added com1 with a serial card then there may NOW be a conflict with the UIC card using com3. Open their properties and see if it says there is.
The easiest thing to do is shutdown, remove the serial card, reboot then see if the UIC works again, if so then there is some kind of conflict involved.
What I found was the UIC baud rate had defaulted to 9600 instead of the 19200 I was trying to use it at in RsLinx...
Thanks for all the ideas...
John
I'm trying to use the 1747-UIC USB (DF1) adapter on an IBM ThinkPad. I,ve installed the correct drivers. The problem is that the module shows up...
2,150
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
408
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,301
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,437
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,256
