1747-uic
tech1
Aug 2011
middlesbrough
i have a 1747-uic when you start driver as a rs232 df1 what do you do with the driver on the program ie-the AB_PIC-1 what do you change that to or do you leave it?:confused:
I think you are choosing the wrong driver.. after installing the drivers you should have "DH485 UIC devices"
You should only be using the DH485 UIC Devices driver, not the DF1 or PIC. Personally, I would remove the other drivers (DF1 and PIC)
lol no worries... was bored on the road and hitting the refresh button.
good to get confirmation on my thoughts anyways.
If you are running Windows 7 64 bit you will have to use DF1 driver for a UIC
When you load RSLinx on the PC and if its a 64 bit machine RSLinx will not install all the drivers, only the one that are compatible with a 64 bit system
See attached screen shot for using DF1 driver and the UIC, this can be used for all systems if needed as RSlinx 6.3 and earlier did not have 'UIC devices' driver
thanks,got myself a windows 7 laptop and a uic adapter and alls ok now.
spot on with the pic driver being missing.the instructions with the uic driver tells you to use the rs232 df1 driver.also there is a uic driver which i used and seemed ok.
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
413
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,304
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,450
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,263
Hey all, first time posting. I have gotten a lot of great info from all of you in the past. I have searched the forums and google as much as...
3,489
