1747-uic
PERSPOLIS
Jun 2002
ontario
295
HI EVERYONE
Can 1747-UIC can be used instead of 1747-PIC to communicate between SLC 5/03 and panel view 550 cat# 2711-B5A5 which is RS-232 (DH-485)communication port. As you know PIC can only work with real serial port of the laptop .
Many thanks Perspolis
HI EVERYONE
Yes you can use the 1747-UIC to communicate with equipment that is using the DH-485 communication protocol from a PC with only USB Ports, in the same way you would use the 1747-PIC from a PC with a Real Serial Port.
EDIT: that is what you mean, Right? The UIC does is not used to as a communication link between the SLC and the PanelView. It is used to communicate between the PC and the SLC or PV.
BCS
BCS
Thank you for the reply and correction. Yes you are right, I meant what you stated (It is used to communicate between the PC and the SLC or PV).
Regards Perspolis
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
409
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,301
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,438
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,256
Hey all, first time posting. I have gotten a lot of great info from all of you in the past. I have searched the forums and google as much as...
3,483
