1756-L61 clear major fault on power-up
snaoum
Feb 2009
Wilmington
39
If I have a major fault I want to be able to clear that fault by cycling power to the PLC. I have a CF card and would like to load from it on power up so if there is a fault in the field the customer and cycle power and clear any faults that may have occured. How do I do this, Im going through the manual and I dont see any specifics on how to do this.
Any help please?
Check out the Fault Routines.
You need to run it on start up and clear the fault.
There's an option to load from CF but I can find it anywhere.
If youhave tech connect, they'll be able to help you out and walk you thrrough it.
The SLC 500 does this through a status bit on controller properties clear major errors on startup however I haven't worked on this particular module to know if it has something similar
Hi All, I'm trying to upgrade from 1756-L61 to 1756-L71 but I keep getting an error 25299-0. Is there anything that need to be complete to be...
1,839
Hi; I am experiencing a problem with AB 1756-L61 controller that it doesn't retain the program while battery is connected. I have found that...
2,780
hello i had a 1756-l61 with firmware ver 13.24. a solid red made the processor not functioning. i ordered a processor that came with firmware ver...
3,825
Hi, we are using 1756-L61 PLC redundant system in one location . due to some minor faults , we upgrade the firmware from 19.52 to 20.58. after...
1,339
1) I am currently trying to integrate a Prosoft MVI56E-MCM Module into a 1756-L61 CONTROLLOGIX5561 that is a redundant system (CPU is redundant...
3,432
