1756-L62S Safety Task
Abuuramu
Aug 2012
Queretaro
19
Hello everyone.
My question is about a safety tasks, the PLC is on fault due to a watchdog time expired. The solution is very simple, download the program or modify the watch dog time of the safety task.
But the PLC does not allow me to download the program, a have been reading about this and i found that the safety task of the PLC is locked and this condition does not allow me to download the program or modify the parameters of the safety task.
the question is how do i unlocked this task?
thanks.
Is this a new machine or has it been running for a while?
If it has been running for a while, what is causing the increase in scan time?
This machine has been running for a while, about what is causing the increase of the scan time... honestly i do not know.
I have been trying to unlock the safety task but i do not know how to do it.
First i thought that the PLC was locket, but is not.. only the safety task is locket.
Regards
Does you safety application have a password?? If so you will need this to unlock. To unlock right click on controller properties or choose Edit / Properties. Select the safety tab there you will find safety lock/unlock. If there is no password then you should be able to unlock
Unlocking the safety task will require regenerating the safety signature. This has legal / liability implications.
Thanks for answer.
So... as a resume i will not be able to modify parameters or download the program until the vendor of the machinery send to me the password, right?
some one of you guys have a document or tech note were explain the configuration and management of safety tasks? a have been searching for information but i have not found useful information.
what makes you think the safety task is responsible for the watchdog fault? Its been a running system and no edits have been made in the safety task, mostly likely its somewhere else.
I wasn't 100% sure but I just tested this. You can download even if the controller is safety locked and a signature has been generated. Provided that the signature and controller match. See table 34 in 1756-UM020 page 112.
It sounds like either your copy of the program doesn't match or there is some other problem.
Hi all, I have an issue with 1756-L62S (revision 20.13) safety lock. We can't figure out who put safety lock on our project. Before I try...
1,028
So when going through creating logs of all our safety signatures for tracking purposes. I found one PLC without a safety signature. This one is...
9,048
Hey guys, Been having an issue with a AB CPU 1756 L62S (red safety) randomly losing the program while in run. Things i have tried or replaced...
4,351
I purchased some re-claimed racks with L62S/B and partner controllers. The safety is locked and I can not download or re-flash without the...
6,079
Hi guys, We have a LSP whose battery will not keep the program backed up and needs to be replaced. The new LSP is FW Rev 16.20, while the L62S...
3,264
