Factory reset 1756-L62S
uminded
Jun 2016
Canada
I purchased some re-claimed racks with L62S/B and partner controllers. The safety is locked and I can not download or re-flash without the password. I removed the battery on both cards and set them overnight with no success.
Is there a way to completely wipe the memory? I want a fresh controller to use for a future project.
From the manual:
> You cannot reset ownership when there are pending edits to the module
properties, when a safety task signature exists, or when safety-locked.
Any idea how to reset to out-of-the-box condition with the safety lock?
From the manual:
Pending edits shouldn't be an issue.
But you should always be able to Flash the controllers back to default factory settings, completely erasing any previous security configuration.
I cannot think of any scenario where flashing the modules could have any (previous app and data) security issues.
Put key in Prog and you should be able to flash the processor. This is the only way to recover as far as I know.
Also for this processor disconnect the battery then power it on for 20 seconds and back off.
Simple battery disconnect will not do anything.
Both of these together was the secret sauce! Just putting the key in PROG ControlFLASH wanted the unlock password. Doing the no battery boot and then PROG worked perfectly.
Had me worried there for a minute though, now I can get back to my project Monday without this one stress at least.
Thanks!
You need to do only one of two suggestions, both will equally clear program memory completely, including safety lock.
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
I want to factory Reset my 5380 (5069-L310) I have here in home lab. Reason being I want to make a Internal How-To video for Setting the IP...
542
Hi all, I've read the thread below which is similar to my situation... https://www.plctalk.net/qanda/showthread.php?t=127711 But I am unable to...
620
I've got a G4(board only)with a MMI port problem. I do not know the IP, but I believe that port works. Is there a way to reset the device to...
557
I purchased a used Pro Soft AN-X2-AB Ethernet Module and wanted to know what is the process to reset the module back to factory. I assume it has...
1,464
