1769-boolean
chantecler
Feb 2013
Caracas, Venezuela
59
Hi, I have a project to migrate one Simatic S5 with 48DI and 32DO. I plan to utilize an A-B CompactLogix 1769-L30ER
The cabinet also contains 4 very precise timers that produce a pulse every time they are triggered by a S5 DO.
My question: Is it possible to use a 1769-BOOLEAN module to substitute such timers?
I haven't found much info about the module nor sample code.
The synchronization of the pulses don't need to be as precise as the duration.
The timers have a precision of 0.1msec but I'm sure 1msec will do. The range of the pulses is between 30.0msec to 50.0msec
Thank you
Another option I have to get rid of the old timers is to utilize a 5069 Compact with a fast DO module, but first I have to compare pros and cons. Also can include an encoder to get rid of the cams as well.
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
108
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
406
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
267
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
114
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
498
