1769-L35E Firmware Download Failed
Hal9000
Jun 2010
London
140
Due to a UCP power failure my 1769-L35E CPU has been inadvertently killed during the firmware update process. (don't laugh - it's not funny)
I’ve tried the following but still not having much luck connecting to the CPU:
· Disconnected the battery for >30 mins
· Ran up BootP and manually entered mac address into the relation list, right clicked and selected reset to default net settings. Made no difference.
· Can’t ping the unit (192.100.1.10)
· Tried an RS232 serial connection. Note when I was setting up the RS232 DF-1 device in Linx and I click “auto-Configure” it says communication successful for 19.2 8N1, however it will not browse the CPU.
· Pressed the CH 0 restore to default button. Made no difference.
· Ran up ControlFlash (11.0) but cannot browse the CPU, so can’t proceed anyway.
LED status:
MS = red
NS = red
Link = off
CH 0 = blinks green when host PC is trying to communicate via Rs232 – DF1. Once every few seconds.
Let me know if you have any further ideas to help me out?
failing that, next stop Rockwell for repair!
You have got a CPU that we will call 'bricked'. It will be more use as a doorstop than a PLC.
Flashing firmware is always a risky experience, and as you lost power while you were flashing it the CPU is now dead.
You could try sending it back but I wouldn't hold my breath.
Cheers
Mark
Hi there, I have a 1769-L35E cpu that I need to make program changes to. It’s running an old firmware version (12.12). I’d like to update the...
4,569
Hello, I've recently updated one of our L35E/A firmware from v13 to v19. I get the warning of: (References changed @v16 I think) Warning: Line...
3,403
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
428
Hi, I recently tried to change the IP address of my 1769-L35E Series A, since doing this the MS indicator is flashing red and the NS indicator is...
935
Good morning guys. Im triying to communicate 4 JXC91 with a 1769-L35E AB CPU. I already test the JXC91 with a newer AB CPU using eds files and...
1,460
