1769-SDN and EX250 SMC DeviceNet
Aye Min Ko
Jun 2014
Yangon
This is my first time using DeviceNet.So i have some problems.If somebody know , please help me.I am using 1769-SDN and EX250 SMC .I use RSNetworx for DeviceNet configuration.When i go online, i found my devices SDN and EX250.Under SDN Scanlist tab, i found EX250 in available devices.So i move it to the Scanlist, but it show me warning "EX250 does not contain any I/O data".Then, i go and see at Input and Output tab, no I/O data.In Edit I/O Parameters, Strobed, Polled , Input Size are all 0 bytes.If i change manually it to 2 bytes, connection to EX250 losts.I don't know how to map the data. Thanks a lot
With Best Regards,
Aye Min Ko
All Found myself in a situation where I need to flash the 1769_sdn Devicenet module from 2.002 to 4.004. I uploaded from the module but it has...
2,406
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,411
Hi anyone, We have a DeviceNet scanner 1769-SDN that is putting out " 08... Er" on the display. Anyone know what that means? We are not able to...
1,746
I am using CLX L35E PLC. There is a 1769-SDN module in slot 1 of this PLC. When I want to view the devices over RSlnx, all devices are displayed...
1,540
Hello, I'm trying to replace a 1769-SDN devicenet scanner on a compactlogix system. The issue i'm having is when i replace the scanner and...
1,895
