Thanks Jasper for the information about 1784-U2DHP. Migrating to ethernet means getting a new PLC which is ethernet enabled? A possible gateway, can you suggest?
Thanks Tamir for your info too. If it meant to be a lower OS like yours, then well do it basically the plan will be Win 7 PC.
I also have concern with the licensing of the RSLinx on the unit. From my reading, there should be a tool from the package where I can transfer the license into a USB, is it? Other says, if none, I need to call AB support, they might deactivate and then issue a new one. Should this be the case? The client dont have any documentation at all including the possible floppy disk with the keys, or anything.
I'm just new to AB brand here, sorry. I would appreciate for your input regarding how can I transfer the AB license from the old unit. I dont have much time visiting the site, but I'm researching all possible steps to go through getting all the needed info from the old unit, once I get there again.
Thanks.
Thanks.
