1784-L84ES issues
geniusintraining
Jun 2005
SC
8,278
This is a new processor (2021) sent it to a customer and they said they were having issues so I told them to send it back and I would take a look
It looks like they tried to flash it but something went wrong, see this video of it
I was going to try and re-flash it but now the comms will not work either, anyone seen this before?
Cycle power to unit: Assert in file S:/LNX/NetlinxUCS/NcsSrc/CommPorts/NcsLinkLayer.cpp Line 489
Here is the video https://www.youtube.com/watch?v=GWbV7d-Sn5w
It the same with the card installed or without, this is also my only one or I thought of trying to make a card with the firmware and trying and boot it that way?
Anyone have any ideas? or is this now a $10,000 paperweight
Next I am going to try an enbt to see if I can go in that route but the USB is dead
KB BF21669, access level anyone
Cause, bent pin on backplane connector, send it in for repair.
Edit, I can't read, the wrong cpp file is implicated in the KB article.
dmroeder said:
Well it might not be
No I bent the pin back and its working perfect... not sure why they made the pins so small, it was one on the outside so it made it easy, I bent one on a EN2T in the middle and that was a pain
Contr_Conn said:
Long shot, but try Stage 2 reset described on the page 88 of this manual
Good to know, I will keep this one bookmarked
Thanks again
Mark
I have found that the best tool to lift bent pins is 0.7mm mechanical pencil with metal tip.
Specifically Pentel P207
Good trick... I have some small / long needle nose that work OK, the 1756 like a push in pin (as I am sure you know) so when it does get stuck it pushes inward so if you can grab it you can pull it back and reset it, that part was a good design, it would be a pain (a real pain) if broke the pins off
Easy... they are a thin wire and if you look at them wrong they bend, I have done it myself several times, if you are not perfectly square with inserting it in the rack it will or has a chance of bending
Why Rockwell won’t design the most expensive components’ physical interface to use pads rather than pins is beyond me.
Leave pins/springs to motherboards and backplanes.
Hello, I have a 1784-U2DN, and I have a flashing red light on the module status LED. Manual says I have a recoverable fault….but it doesnt say...
915
I am "upgrading" an XP laptop to Windows 7. I have a 1784-PCMK Series A card. Having trouble finding specific drivers and getting the card...
2,826
I need a new 1784-u2dhp, and I am getting quoted $5000 CAD for a replacement communication adapter, which is as close to highway robbery as it...
3,164
Hey everyone, Ran into an issue on a customer's system a couple times recently and wanted to check if anyone might have any clue what's going on...
1,402
Hey guys I think my 1784-pcmk card went bad. I was wanting to confirm, and ask what are my options for communicating without using RS232 port on...
1,962
