1785 ENET - What is a Transceiver?
Sep 2003
Philadelphia
75
I bought a PLC 5/60 system off Ebay. It came with a 1785 ENET card as well as a Black Box transceiver. I've read here that the transceiver is required to connect the ENET card to a RJ45 plug and the rest of the network.
What is a transceiver? Why can't you just connect the twisted pairs to the 15 pin plug.
Thank you for any help you can offer.
Frank
Without going into a history lesson on ethernet, let's just say that a transceiver is a component that has long been required for transmitting and receiving on ethernet.
Ethernet used to commonly be used with a thick coax cable (thicknet or 10Base-5) or with a thinner coax cable (thinnet or 10Base-2). Devices usually had a standard interface called an AUI connector. You purchased a transceiver based on what network cable you were using (thick or thinnet). Go find some older ethernet devices like hubs or PC NIC cards and you will likely find this AUI connector.
As technologies developed and twisted pair (10Base-T) grew in popularity you found more and more devices with the transceiver built-in to the device. This was definitely more convenient but did commit you to one cable type. Today, thick and thin net have all but disappered and tranceivers with them. But older devices like the PLC-5 still require them. Even the first ControlLogix ethernet modules had an AUI connector along with the 10Base-T.
However, the 1785-ENET module does not require the transceiver as it has an RJ45 connector (10Base-T and 100Base-Tx) built-in .
OG
Thanks for the help.
Thanks for the help. I guess I will try to find more info on an AUI. I didn't realize that ethernet ever was anything other than twisted pairs.
I think the newer ENET cards come with an RJ45 connecter. Mine has the 15 pin D shell.
Again, thank you for taking the time to answer my questions.
Frank
We have many sites with PLC-5s and 1785-ENET sidecars that are being pounded pretty hard by the GE IGS driver (Kepware) and iFIX/Historian...
1,003
I have a plc 5 with a 1785 ENET card. I'm getting a flashing red stat light. Reading the manual I see its a dual port system call failed. How...
1,861
Hello all. I'm currently trying to configure a 1785-ENET/B module. It is attached to a PLC5/30. When trying to configure it from within rslogix, I...
2,029
I have a PLC5/30 with a 1785-ENET sidecar. Occasionally if I turn power off to the rack for more than a few seconds, the ENET sidecar forgets its...
1,641
I've just changed the IP address for PLC 5/40 with 1785 ENET but I found somethin wrong on RSLinx classic. Last IP is 172.26.52.1 and the new IP...
9,063
