2 Mitsubishi FX5U Online Monitoring Issue
aandjsam
Sep 2016
lincolnshire
30
Hi all,
I'm hoping one of you has encountered this problem before..
I have two Mitsubishi FX5U Processors on site, communicating over ethernet with simple data transfer between them. when running together, they run absolutely fine, however, if I want to go online and monitor one of them, I can't due to a communication error. To monitor them, I have to unplug it from the other and monitor it separately, which is a complete pain.
I can ping both processors with no problems, and as I've said, they work fine, they can read each others data with no problems.
Have any of you come across this fault before? if so, what did you find to be the remedy?
Thanks!
You may need to set up more sockets, I have not used the FX5 but in the older Q series Enet card you can set up multiple sockets (ports). I have done this with GX configurator. You can specify Melsec Connection I suspect that the setup of the ports has only been done for the current communications.
Hello there is a way to do the polyfit on 3rd degree on this plc. for imput i have a munimum value of 5 X and 5 Y value for example Measured...
58
2,667
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
168
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,274
Hi everyone, I am having a hard time trying to get a connection between this two devices. I am already lost on what went wrong. Please help me~~~...
858
Is it possible to have FX5U plc using sinking inputs and an expansion module FX5-16ES with sourcing inputs? The plc has relay outputs so NPN/PNP...
993
