2016 Best Laptop for VM ware
That's fine, but I personally choose my host OS based on where I do most of my work. I makes no sense to me to run Linux as my host OS when I do most of my work in Windows.
I'm currently running an Asus laptop, I-7 processor, 16GB ram, 960 GB SSD. Win 7 Pro 64 Host, Win 7 Pro 32 VM, Ubuntu VM. and a QNX VM.
I could agree to that, but the OP was asking about VMware performance; which I assumed was more important than host OS use.
The best, best is likely to use Windows Server 2012 Hyper-V or VMware ESX type 1 hypervisors; basically just an OS > hypervisor > on hardware.
Running VMware on Windows desktop or even VirtualBox on Linux are both type 2 hypervisors; an OS > in hypervisor > on an OS > on hardware.
I use a Linux laptop with VirtualBox because it boots fast and doesn't waste RAM with the host OS; and I(.T.) won't bloat the host OS with other software services that kill performance.
Any laptop choice you make, virtual machines seem to work best with:
- Lots of RAM (min 4GB per OS)
- Two harddrives (one for the host OS, one for the VMs)
My current setup for work is a Dell Latitude E6540 with an i7-4610m, 16GB RAM, and a Samsung 840 Pro 512 GB SSD. It runs Windows 7 Pro and I use VM Ware workstation 7. I have no complaints running typical business programs on the host with an additional 4 VMs at the same time. Most of the time I'm in my VMs running RSLogix5000 or some version of Wonderware or System Platform. The only complaint I have is that there is some issue with computers that are native USB 3.0, running Windows 7, with VM Ware. I can't get USB to serial converters working inside my VMs. I didn't have this issue on the previous generation latitude which was a native USB 2.0 machine.
Greetings, How can I create some structure tags that are similar to the ones seen in SIMATIC WinCC Tag Management section? Or does Citect SCADA...
1,176
Greetings, How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016? For instance, I want to import some tags...
1,969
Hello all, Work has a copy of citec scada so as a side project i have been trying to set it up and running. I have hit a bit of a wall with...
1,339
I'm building a FT View SE Network Distributed application on Microsoft Windows Server 2016 Datacenter. Original application was FT View SE v8.2...
2,374
Folks, I have an issue with my Excel VBA. When I run the upload script from my machine (Win10 Office 2016) it runs fine. But when I run it from a...
2,867
