24VDC Snap switch
Rson
Jun 2017
Michigan
520
So I have some Rosemount 8712 Flow transmitters that require a local disconnect. They are rated 24VDC - about 1A.
This is an explosion proof environment, and the customer recommended Crouse-hinds switches - of which I found the snap switches.
https://www.cesco.com/resources/pdf_467/ID-BRO-v1-eds-efd-snap-switch.pdf
All I need is a single-pole disconnect - but I notice these only have ratings for AC. I know AC and DC circuit breakers work differently, but this appears to be just a switch. I shouldn't have any issues hooking one of these up to a transmitter, right?
What is the area classification?
Class 1, 2, 3? what division?
what hazardous chemicals?
you must use a switch rated for the area classification and for use with the chemicals.
james
I know the switch is rated for the environment - I'm more concerned about the switch only showing AC ratings - nothing for DC.
Those are manual motors starters, so you would have to add OL heaters to make them work, overkill for a simple switch.
Just buy the cover and box alone, the switches inside are just standard toggle switches, get one with a DC rating on them.
https://www.leviton.com/en/products/12021-2i
And FYI, DC rated switches are a little different internally. DC makes the arc last longer, so they have to have a little magnet inside of the arc chute (magnetic blow-out) to interrupt the current flow without burning the contacts.
Thanks for the replies so far.
This is a class I div I Group C&D I believe. I know it isn't group B.
I'll double check at the office tomorrow.
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
423
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
117
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,147
Good morning, could anyone recommend a 24VDC pulse counter which counts up or down to a preset #? Once it reaches this number, send a 24VDC back...
1,650
UL 508: Any reason I can't supply a 60W 24VDC power supply from 2 legs of 480VAC? Our MechE is asking, it is for a product I don't deal with. My...
5,881
