I think those magical devices are going to be some contactors wired electrically right after the panel breakers, blocking or passing power to whatever electrical load you want to put on your list. Those contactors can be controlled by a PLC program.I was hoping not to "mess" with anything now,I was hoping to hook some magical device to a breaker in the panel then to the ac units,hence only the ac would be denied power and only if the genny had a high load demand.
Ok I'll explain,when I first started all power in shop came from genny.I got two 400 amp panels.I learned that by putting this breaker here and that breaker over there (referring to the panels),I could make the digital amp meter on genny very even.Throw in 15 florescent light fixtures and a couple small drill presses for countersinking,a belt sander,ect...,and my balance went to-not so good-the genny and the cnc's were not happy.I procured some burial wire and with the back hoe ran a 220v 1p line to the shop.I run all the 110v stuff and a buzz box,also 5hp air comp for when genny not running. BTW some of that is or,as in air comp OR buzz box.The rest of your post is completely over my pay scale.I heard about a batt bank to help with demand and dump,kinda like giant capacitors,-I think.I went with genny because I was out on the street(lease was up,landlord had new tenants willing to pay a lot more),my barn/building was about done -no power,so the 54 was bought and away we went.I'm going to call automation direct and talk to tech support and see what they say.I'll let you guys know what happens,Rob
An adjustable current monitoring relay in the generator output along with an adjustable time delay relay to restart the shedded load, the AC units in this case, would probably be adequate.
I agree with these views. As PLC programmers, often all problems look as if the best solution involves the latest, fanciest, most advanced PLC. It is the view of the infantryman in the trench fighting a battle, and I understand that viewpoint. The best gun looks like the biggest, fastest-shooting bad dude with the largest available magazine.I do not think a lot of automation is what you really want to do. Manual load control will best serve your needs and allow best flexibility. You are a machinist - that is what you do best and make the most money doing.
Programmable Logic Controllers are not generic (not yet at least), and each brand has it own little progrqamming software that will allow the user to write a program for that brand only.Do they use G code like my machines or maybe there like the latter that makes the G code work,I was told that there is a device to do what I need and plc was in the old guys statement,as well as scientific atlantic,found them got confussed,and now I'm here.
