On the other hand, there are the programmable "smart relays" that Okie hates so much, that you could learn to program in 30 minutes, with no software or cables to buy, and probably a smart relay would do your job (barely).
As I see it, the basic function is:
"If generator current >= XXX, then switch Contactor off to prevent Load A from starting or running for X minutes".
That basic function can be done with a current transducer switch, a smart relay, a PC computer with programmable I/O module, a PLC, or a PLC with operator graphic panel. Each of these levels adds capabilities but also increases the cost and required knowledge level.
On the other hand, if the control device needs to consider several load possibilities, and pick the best one for any given set of input parameters, maybe by inhibiting several loads instead of only one, then a PLC is a good solution.
