3-Wire Transmitter Analogue Wiring
Problem Solved
All,
I know it's been a little while since the last post, but I located the installation guide for the PWM-1400 (was not sent with the drivers o_O) and thought I should close out this thread completely .
I've attached it for any of you who are interested at all.
And I am using a signal converter (4 - 20mA to 0 - 20mA).
Thanks to everyone for your input.
Regards,
Joel
All,
Regards,
Joel
Thanks for the update. Good to hear problem solved.
I see the control current signal connects to terminals 1 and 4. I was wrong and I am sorry if I mislead you. It was not intentional.
Hello, I have a simple 3-wire 4-20mA pressure transmitter which I would like to split into two signals to send one to the devices interface and...
3,630
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
268
I have read a lot about this. One of what I saw is 4 wire is used when the voltage drop is high because of wire and transmitter itself but I don't...
2,477
Hi, Calculation of voltage drop of a 2 wire transmitter connected to plc AI is pretty simple and straight forward. My Question is could you...
2,142
how to connect three number 4 wire transmitter to analog card IF16 1756 plc
3,268
