3x register and DTM Browser Unity
the18
Nov 2019
Casablanca
18
Hello,
As the title suggest,
I need to read 3x registers from multiple slaves using Modbus TCP on unity pro with DTM Browser, but i can't seem to find where i need to define that i am trying to read 3x registers and not 4x registers.
Can someone please help me understand how it is done or am i missing something and thank you very much.
I might be missing the plot, but from my experience the DTM browser is not for Modbus Tcp/ip comms. It is for Ethernet IP (Might be for others but I have only used it for Ethernet IP).
Depending on what hardware you are using you need to use IO scanning from a NOE card or depending on the cpu ethernet port.
You can also use read_var FB for this but IO scanning is better way to do this
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,154
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
164
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
298
I would like to copy register N61:131 thru N61:147 into ST252:0 I keep failing What happens is I copy into ST252:0,1, 2 etc. What am i missing...
18
594
Hello Siemens experts. I am trying to register a GSDML file for an Endress & Hauser's Profinet IO over APL (Profile 4.0) compliant device. TIA...
213
