4-20mA Float switch wiring questions
santisiah
Nov 2013
Albuquerque
Hello,
I have a float switch that is labeled as below and has only 2 wires (red,black):
Input 10-30VDC
Output 4-20mA
Resolution 5mm
I am using an Analog/Digital card and need help wiring...
The card shows CH1: V+, I+
V-/I-, SLD
I'm assuming I use the 24VDC from my power supply but do I just hook that up to the red and then the black to the V-/I- and jump to I+? Do I need a resistor anywhere?
Thanks a lot
Which is it analog or digital. Can you post the complete catalog number of your card. Can you also post the complete catalog number of your float ( switch?) or is it a level transmitter. A 4-20ma output would indicate a transmitter not a switch.
It's actually an Analog input module.. Mitsubishi L60AD4 (I guess I called it analog/digital because of the AD).
The float is a transmitter, sorry I called it a switch, but it is a continuous float that is 4-20mA..
Hi wire the card like this picture.Note the V+ and I+ are linked.
I would assume the float is loop powered but check your manual.
If it is take the +24V from the card to the + of the sensor, and - of the card to the - of the sensor
Hi
I haven't used that particular card.
Link out the V+ and I+ and see what volts you get between I+ and I-.
The manual says you MUST link it together for a current input.
Report back with your findings
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
275
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
277
What's your go to 4-20ma isolator. I've got some 4 wire 4-20ma from several flow meters and scales that I would like to isolate before it gets to...
1,696
Hi, I need to read three 4-20mA signals from a DCS(ABB) in a remote 6 channel analog input module with RS485 modbus port. When I connected...
489
Hello this is my first post. Looking forward to being more involved in this community to learn and hopefully help others. Any help or guidance...
791
