4-20ma I/P connection problemb
nilesh_1106
Dec 2011
pune
34
Hi Everyone,
I have Siemens s7-300 2I/P analog module i.e 6ES7-331-7KB02-0AB0 So I want interface a Isolator which having 4-20 ma output to analog card as 4-20ma input. but I am not getting the exact hardware connection to the module as its act as independent current source.also i don't know that it will act as 2-wire or 4-wire?.please help me out.
Hi, Nilesh
First check wheather u have configured proper module in hardware configuration in Simatic Manager. Check what u have confgured that channel as i.e 0-10 v or 4-20 mA or RTD type ...the check the connections made to the terminals of the modules r correct or not and try to read the counts in VAT table. Also get the transducer catalog or manual for reference.
Hope this will show you the way ..
:D
I am connecting a 4-20mA signal from an RTD transmitter to an ABB ACH 550 drive. My sensor is an ACI RTD Freezer Transmitter with a range of...
1,758
hi guys. im new to analog system. ive been doing a temperature reading from a sugar tank. I have made connection frm the RTD to a 4-20mA...
2,107
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
281
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
281
What's your go to 4-20ma isolator. I've got some 4 wire 4-20ma from several flow meters and scales that I would like to isolate before it gets to...
1,702
