Just curious - I see there are channel configurations for the 5069-IF modules that let me type in the high & low Engineering units as well as the signal units.
Changing these does nothing to the signal, however. I have to actually open up the module settings, change it there, and click 'apply' with or without inhibit in order for the engineering units to change.
Is there any way to make these change from an HMI screen directly to the configuration bits? Is there an apply changes bit somewhere that has to pulse on/off that I'm missing?
If not, I'll probably just ignore the module scaling and use a compute block to do the scaling so it can be done from the HMI screen.
Thanks!
Thanks!
