!761-net-eniw
cesar2112
Feb 2005
I am trying to program a counter that will be displayed on the net using a A/B 1761-net-eniw and using a micrologix 1500 does anyone know how to do this?
Cesar:
With the 1761-Net-Eni, you have to do the following
1) Download the neteni utility from www.ab.com
2) Power the net eni with a 24 VDC power supply, external power supply preferred
3) Set ethernet address on the 1761-net-eni using the Neteni utility and your PC.
3) Install a serial cable between the NET ENI and the micrologix serial port(0) or (1)
4) Install an UTP cable between your NET ENI and your industrial switch
5) From the switch you can access the Micrologix
I hope this can help
Widelto
Thanks for the info., I have already installed the unit and it is working.
I can retrieve the program on the micrologix through rslogic using the ip address through linx eithernet gateway. The dni program from A/B is a nightmare, the instructions are not clear and alot of trial and error
I need now is to send a message through the eithernet and use the webpage to see a counter running off an input or counter,
Does anyone know how to write this program in the ladder and how to display it on the 1761-net-eniw webpage.
Dear, I have to communicate my SLC 5/04 CPU channel0 ,configured as DH485, i have an ethernet interface 1761 NET ENIW. I have read how to...
3,924
please help me. i am trying to take to this by using ENI Configuration Utility, but i cant load when i try eni ram or eni rom. i am using...
1,440
please help me i need to know how to set this up step by step, thia is what i have ! slc 5/04 1761 net eniw rslinx pro ver2.2 iam using...
10,271
Can anyone help place a message in a string data file so that it can be sent via email to the desired location.Any code using RSLogix 500 will be...
2,295
i connected the device to a 1500 PLC, and it is working fine ( i can load and download programs to and from the PLC using RSlogix ), problem...
47
9,400
