842D DeviceNet Absolute Multi‐Turn Magnetic Encoder
swva
Aug 2013
WV
According to LED light on my
842D DeviceNet Absolute Multi‐Turn Magnetic Encoder, the encoder is"Active but not allocated by master devicenet". Can someone explain what this means and how to fix it? Thanks.
Hi
Only a guess but have you assigned it in your scan list?
Is this a new encoder or a existing one.
Donnchadh
I am using a Rockwell 842d absolute multiturn encoder with a 1747 SDN Devicenet scanner. Where the encoder is a 26 bit encoder I was expecting to...
2,198
Hello everyone, I wanted to change/reset the position value of the above encoder. I have RSNetWorx for DeviceNet and RSLogix5000. What is the...
2,325
Hi Everyone, I replaced encoder 842D-60131331BXA with a new same part number. Dip switches and Preset Push button are considered. When I tested...
241
Hello all. Looking for a bit of help concerning the service code necessary to save parameters to an 842D absolute encoder. The user manual is...
2,933
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
24
