9Vdc to supply 4-20mA simulator
Yes, the Druck that Nonuke suggests is a very nice pocket size calibrator but if you wnt to make one drop me an e-mail and I will send my circuit. I use 2 x 9V but it will work with 1 into a low impedance load.
roy underscore matson at yahoo dot ca
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
219
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
600
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
445
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
245
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
553
