A/B Pulse Train Output
AllenF
Aug 2002
Southwest Ohio
24
I have a question about the Continuous Jog mode.
I'm using a ML1200 to run a simple 1 axis servo (Ultra).
When I got around to programming the Jog features, I ran into
a problem of reading from the PTO and updating the machine
position on a PanelView300 when the PTO is set for Continuous Jog.
I abandoned trying to use the Continuous Jog mode.
I did a workaround by checking the jog button, issuing a set
number of pulses, update the position, check the jog button
and repeat if jog button is on.
This works rather smoothly to my surprise.
The PTO operates independent of the program scan, hence you can
only read number of pulses output and update machine position after
it is done.
This seems to be the case for Continuous Jog mode also.
Have I missed something here? Is there a way to keep track
of the pulse output while it is in Cont. Jog state?
Thanks in advance,
Allen F
I have not used the PTO before but when programming a jog in the 1394 servo controllers, I usually start a move command to the soft position limit. Then I monitor the state of the jog pushbutton and when the operator lets go, I issue a stop axis command. This has the added benefit of never letting the operator jog past the soft limit.
HTH
Norm Dziedzic
Belden Machine Corp.
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
3,330
Hi, i already make a program CP1E with pulse train ouput (PLS2) to control stepper vexta. Can i use work online simulator in cx-programmer to see...
1,461
There is a machine in my plant with an obsolete Omron PLC in it that I need to replace. One of the outputs from this PLC is to a stepper motor...
5,664
question what is the maximum number of pto outputs you can get if you use a micrologixs series plc? If I can remember correctly, you can get a...
5,618
I am using a Panasonic FPX 14 I/O PLC w/ Transistor outs to control a servo/stepper motor for an automated infeed on a retrofit punch press...
2,883
