I was just curious as to how the .csv file was going to come out when using DataStore plus on a PVP 7. When the "Trigger" transitions from a 0 to a 1 in the PLC the Float and/or String data that is defined in the DataStore plus setup is captured and put into a .csv file. But my questions are is if say the Float data changed while the "Trigger" is still 1 does that data all get recorded? or does the only data that gets recorded end up being what the Float had in it when the "Trigger" originally transitioned from a 0 to a 1? So say you wanted to record the starting and then stopping time of a cycle on a machine. Would you "Trigger" the datalog to start at the beginning of the cycle then keep it "on" until the end of the cycle, it will then record that end of cycle float data and one would turn the "Trigger" off in the PLC logic. Or would you setup the trigger so that at the beginning of the cycle it came on for a moment, recorded the data that it needed to, then cycled back off in the PLC logic waiting to be cycled on again for the next time it needs to log data, in this case the end of the cycle. Thanks to anyone that can hopefully clear this up for me!
