A900 to FX2n
karlag
Mar 2006
Canada
81
Helo, I am looking for cabel pin-out schematic to connect GOT A900 to FX2N. The GOT A900 side is RS422 (25 pin).
Thank you!
don't have time now but here is connection diagram showing 25-pin conenctor side on A900 (you may have to modify other side to match FX). this is taken from SH-NA-080013 but you should also check SH-NA-080119 for example (sample attached):
I have a Mitsubishi A985 GOT HMI and I am trying to upload from GT designer 2. I have a USB to serial connector the driver has been installed and...
1,276
hi there again:) i know a lot of you are fmiliar with mitsubishi touch screen products, have anyone encountered got-a900?i was somehow confuse...
2,802
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
119
Dear all, what type of built in port does fx2n-80mr plc has? i mean is it rs232, r rs422 or rs485. and which module should i use to convert to...
124
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
564
