mitsubishi hmi: got-a900
theripley
Jul 2008
laguna
545
hi there again:) i know a lot of you are fmiliar with mitsubishi touch screen products, have anyone encountered got-a900?i was somehow confuse with its interface with PC, must i use the a9gt-buss or an rs232c would do?if an rs232c would do, can i use an ordinary rs232c, i mean something you can buy on the computer supplies & not the rs232c interface of mitsubishi? hope to hear from you soon :)
best regards,
theripley
hello ,
i am new to mitsubishi touch screen and am currently using a diff model. But also i am using a 9 pin just like you. i found out that although the 9 pin used is the normal type(ones u can find in pc store) but the wirings are different. you might wanna check the wirings from pc to GOT. Hope this helps.
Sincerely,
Al
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,313
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,390
i have an HMI touch screen with type mitsubishi GOT970 and i want to take a backup of the programme inside it to be installed on another one which...
7,123
We have a system of Mitsubishi PLC , GOT HMI and a EPSON Printer connected to HMI. All was well but suddenly printer stopped responding although...
1,441
Hi everyone. Have got a dead F940 GOT HMI. Put 24v to it and plugged it into FX2N PLC but no joy. It has run ok for two years then left outside in...
5,052
