Mitsubishi GoT HMI problem
engdarsh
Jul 2013
alex
i have an HMI touch screen with type mitsubishi GOT970
and i want to take a backup of the programme inside it to be installed on another one which has no OS
which software can do this ????????
welcome to the site
It is GT Designer 2
but not an easy task because of the age of the HMI
thank you sir
i got the software and try to do using USB to Rs232 cable but i am getting a communication error "Timeout error 0259"
i checked all what can make this error comes and problem still
cable is ok and well connected
configured at the correct port
HMI is powered on
and i tried all baud rates from the lowest one
please tell me what i can do?
it is difficult not seeing what you are.
for me it has been about 2 years since I did this.
can you confirm the connections?
is this an S232 o USB converter or a Nul modem cable
what is the Pinouts
is it (2-3 & 3-2) or (2-2 & 3-3)
of the top of my head I cant remember
I will look into it tonight
i have a USB to RS232 male cable..and the HMI pinout is male also . so i put a converter female-female in between..is that right??
can i take jumbers to make connection
2-3
3-2
5-5
4-6
6-4
this nul modem cable will be connected between RS male pinout and HMI male pinout or this direct between PC and HMI?
looks ok
I have been looking for the info
it is heree in my organised mess somewhere
still looking
the only posible change could be
2-2 & 3-3
instead of
2-3 & 3-2
this is usualy the issue when comms won't talk
i succeeded with this connections
2 - 3
3 - 2
5 - 5
4 - 6+8
6+8 - 4
but now another problem>>>>>
error occurred <00000133>
GOT Type errror occurred
although i choosed the correct HMI model
& the controller is MELSEC-FX
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,318
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,393
We have a system of Mitsubishi PLC , GOT HMI and a EPSON Printer connected to HMI. All was well but suddenly printer stopped responding although...
1,441
hi there again:) i know a lot of you are fmiliar with mitsubishi touch screen products, have anyone encountered got-a900?i was somehow confuse...
2,811
Hi everyone. Have got a dead F940 GOT HMI. Put 24v to it and plugged it into FX2N PLC but no joy. It has run ok for two years then left outside in...
5,057
