AB 5000 conversion for s4 TimeBase?
dclough
Sep 2006
rome, ny
I'm converting a program from a micrologix to a controllogix. In RSLogix 5000, what would be the equivalent for the S4 Timebase? The program uses nearly all the s4 timers...
I assume you mean the T4 timers... right???
In Control/CompactLogix, all timers are millisecond timers. (.001) There is no selectable time base.
Nope, I mean S4 TimeBase (Free-Running Clock, I think they call it). They are used alot for flashers, because each address has a different on/off rate.
Maybe there isn't an equivalent?
In theory there is.
Using the GSV isntruction and reading the LocalDateTime object,
an array is returned as:
DINT[6] would be an equivalent to the free running clock
Consider using periodic tasks for code that you want to execute continuously on any particular interval. That is the prefered way of doing it and it offeres more flexibility as it does not lock you into a time base that is constrained to time slices of 2 x 2x milli-seconds
However, if you absolutely must have a free running clock equivalant you can create your own with any timer and using the bits of the timer accumulator - FreeRunningClock.Acc.0 through FreeRunningClock.ACC.30. Make the timer preset 2147483647. FreeRunningClock.ACC.31 won't be availalbe because it would normally be the sign bit and a timer Acc can never be negative.
curlyandshemp said:
In theory there is.
I use this method.
dclough said:
ok, obvious newbie here. How is the LocalDateTime set up? it isn't listed anywhere i can find...
Build a tag of the type DateTIme. I called mine Clock. Pretty snazzy eh?
Put a GSV instruction in a rung. Populate it with:
Class Name: WALLCLOCKTIME
Attribute: DATETIME
Destination: Clock.Year (Clock is my tagname)
dmroeder said:
Here is a sample of what we do
Our tag, Time[0], is an array of 7 Dints.
Dang, I'm not very good at the interweb. I had a pic in here at one point, I even previewed it to make sure it worked. Now my work is banning me from photobucket, so I can't fix it.
To add to what Mike said, the Attribute needs to be "DATETIME" in version 15 or below and "LocalDateTime" in version 16.
dmroeder said:
Now I'm a super bewbie, I can see the pic on my neighbor's PC, but not mine. :(
Forget I was ever talking...
Time for the sledge hammer. Why did AB change the #&$@#^ Attribute name? I haven't upgraded to V16 (working on two projects and didn't want to hose anything up) yet. My rep told me that 17 is coming... 16 just got here. <insert standard complaint about retarded software pricing and upgrade policies here>
You can upload pictures for threads on this site directly to this site and Phil will host them. If you scroll down a bit in the advanced posting screen there is a button to attach pictures. Browse to the picture file on your computer and click upload. After a successful upload you will get a popup with the BB code to cut and paste into your post. You will have to have your browser enabled to allow popups for this site.
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
677
Hi, Is it possible to down grade conversion of rslogix 5000 program? I mean if I developed program in version 31 and I want to download same...
731
Hello I have to convert a MELSEC-A Mitsubishi program which works under DOS to Studio 5000 Allen Bradley. What is your opinion is it possible?
2,132
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,452
Respected Experts; Good day. We have 2 number machines which is designed in RSLOGIX 5000 version 10.07. As we know that now windows 7 is not...
2,614
