AB 5069-L306ER ASi Module?
Dariusincj
Jul 2011
Missouri
43
I know there are modules out there but are there any ASi modules for the 5069 series? I'm not finding any. Has anyone tried using the U71003 from IFM?
The ones I've used are Ethernet I/P, So you just set them up using the provided instructions and give it an IP address. BW provides the aoi and data structures.
Caveat - I've only worked w/ the safety ones.
I'm not sure if this will work with a 5069 processor. I read you have to add it as a 1769-Generic module but that option isn't available for a 5069 processor.
Thanks for the help. I think we will just have to change the processor to a 1769 type and get the rack mounted ASi module. Thanks again.
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
1,000
Hey y'all, I have a 5069-L306ER processor and have the IP address on A1 set. However A2 doesn't seem to talk to anything. I tried setting an IP...
972
I am trying to upload from an AB controller ( device info attached). I'm using Studio 5000 v32.04.00. I reach the "Connected to Upload" dialog...
1,558
Lol, our local Rexel has twenty-two 5069-L306er's back-ordered, so what's the deal with so many factory-sealed processors from china on eBay. Are...
3,123
I have a fresh out of the box 5069-L306ER connected to power only. I am unable to set the IP address of the plc through USB OR ethernet using RS...
18
7,356
