AB ControlLogix vs. ABB 80xa using Ethernet/IP
Stig Poulsen
Sep 2020
Denmark
I am struggling to get a 1769 CompactLogix to communicate with a AC 800M controller from ABB.
ABB requires an EDS file from the PLC which I can upload from the controller, but how can I setup which data to communicate.
Anyone with usable experience - pls. advice.
BR
Stig
The CompactLogix can only be a master, not a slave. So the EDS for it doesn't list any slave connections another master could use.
Can the ABB be a slave?
Hi pturmel,
thanks for You answer, I am afraid You are right.
No ABB can not be slave either.
I will probably go for an AnyBus solution.
BR
Stig
Has anybody had luck with read/writing to an ABB RVG200 Paperless Recorder directly from a ControlLogix (Version 30)? Looks like I may have to...
1,622
Hello all, I am fairly new to ABB Robotics (FlexPicker) and have been asked to see if there is a way to get status bits to a ControlLogix PLC...
1,366
Hi everyone I need to read/write data between an ABB AC500 and a ControlLogix via Ethernet Any suggestions? Does the AC500 support EtherNet/IP...
3,101
I am trying to setup communications between a Allen Bradley ControlLogix plc with a Direct Logic DL 305. I was told I can use Modbus RTU or...
2,595
Hello all, I am starting a new project that has a ControlLogix 1756-L61 processor talking to 2 off ABB IRC5 robot controllers. The communications...
12,902
