AB factory talk ME -> active user -> PLC
Ingis
Aug 2013
Oost-vlaanderen
34
I'm currently using the user implementation that factory talk studio ME has incorporated. The users, related to security level letters. This works perfectly for me. Only I want in my rslogix an if structure in one of my rungs depending on the user security level. Is this possible? So how do I get the logged in user in my hmi to my plc.
somebody has an idea? work around?
best regards,
Wesley
You should be able to use the Global Macro to transfer User Code to PLC. Look in the explorer pane for Global Connections > Macro Tab>Remote Macro 1-5. You can assign a PLC tag or expression to run these Macros.
Note: The Macro you create must be named Macro1 or Macro2, etc. It must have this naming convention to work.
Then Macro is > Form: Tag = Expression So your tag {[PLC]UserCode} and expression {CurrentUserHasCode}
thank you for the reply.
I've got it working like I wanted it :) thx!!
Hello. I need to log data from registers on a CSV file to a USB stick. I have a panelview plus 700 CE, with 5.1 firmware. The catalog number...
2,774
Hey All, I am trying to do some data storing on a PanelView+ and the built in data logging doesn't quite fit my needs. I was looking into the...
5,616
I am creating an application that I would like to have a button pressed and it would bring up a text or pdf document. I have downloaded a sample...
2,734
117
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
66
