Factory Talk ME active x
caddisjt1
Nov 2005
Washington State
I am creating an application that I would like to have a button pressed and it would bring up a text or pdf document. I have downloaded a sample from RA but I am wondering if I have to transfer my document to the panel view plus on a usb drive or can it be done via Ethernet. Where on the terminal would be the location to store this document. They do have a built in pdf reader but I am unsure how to put anything in that location. Any tips would be great.
I always put my PDF documents on the removable media for the PanelView Plus.
On the original hardware PV+ terminals, that was a CompactFlash card, and on the PV+ 6 it's an SD card.
In both cases those are called "\Storage Card2" in the PV+ filesystem.
Unless you have the "Windows CE desktop" model, you don't have very good access over Ethernet to the internal "\Storage Card" filesystem of the PV+ terminal. The File Transfer utility only gives you access to the \...\Runtime folder and the \...\Font folder.
I find it much easier to store and maintain the PDF documents on the removable media card.
It's still a pain to configure the FTP server and figure out the internal file system directories.
I put in a couple of PV+1500's last year that had the CE desktop features, but I still put the PDF documents on the external SD cards because I found it a lot easier to pop out the card, stick it in my computer, and move the files to it, then pop it back into the PV+.
I am still struggling with getting the pop up to function. From RA knowledge base tech note# 121273 I learned a little but I am not sure where to place a file. I did not want to leave a memory card in the terminal. I have created the HMI tags but so far I am unable to get this to function. Any tricks would be great. Thanks
Hi, I'm currently using the user implementation that factory talk studio ME has incorporated. The users, related to security level letters. This...
2,080
Hello. I need to log data from registers on a CSV file to a USB stick. I have a panelview plus 700 CE, with 5.1 firmware. The catalog number...
2,774
Hey All, I am trying to do some data storing on a PanelView+ and the built in data logging doesn't quite fit my needs. I was looking into the...
5,616
117
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
66
