AB High Speed Counter with Encoder
I know I am getting in on the tail end of this, but the encoder on the motor doesn't matter. The HSC card is only connected to the emulated incremental encoder outputs on the drive. The drive talks serially(proprietary protocol) to the encoder.
You state you are connecting to the motor, but that can't be the case. There must be a Yaskawa drive involved.
That will be about impossible. He will first need a VFD that can commutate a permanent magnet motor. After that, he will need to get a converter to convert the Yaskawa serial to incremental. After that, he will somehow have to figure out rotor position.
I guess I shouldn't say impossible, since I have run a PM motor open loop with an ABB ASCM1 drive before. I wouldn't do that for a positioning application, but it is fine for a velocity application.
Thanks very much for the information. This is part of a school project (3rd year engineering). We are limited in our available resources and as such we end up matching up different manufacturer's components. I have found a similiar sized AB motor (Y-1002-2-H00aa) which can feedback to the HSC card. This has caused a new problem as we are attempting to drive it using a Leeson SM2 Flux Vector VFD via PID control with the PLC. I am having a hard time getting the VFD set up correctly so the motor runs smoothly. I also have available an AB ultra 3000 servo drive which I think would mate much easier to the AB motor.
Watching the converstation between you guy's highlights to me my lack of knowledge and your superior knowledge regarding electrical control. Thanks for all your suggestions, feedback!
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
98
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,506
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,824
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,170
Does anyone know how to set the output window on-off values on the fly without having to inhibit the module? I could of sworn when I first started...
2,439
