AB HSC programming assistance
kbradray
Jan 2006
Columbia
175
Although I am not new at AB programming, I am new programming with high speed counters to create an analog output for drive speed control. If someone could give me some programming examples as to how to take an encoder signal into an AB HSC and to get a following analog signal to an AB analog output card I would be grateful.
I will be using a Microlgx 1100 series processor with AB 1769 HSC and analog out modules.
Thanks in advance
Thanks in advance
Do these pieces of equipment not come with manuals? I always find that the examples in the manuals are very good to get me going in the right direction. As for the analog output, once you have the information from the HSC in your processor, you can do with it as you please in its digital number form. You need to send the analog module a decimal number in the proper range that will in turn be used by the module to give you the current or voltage output you desire.
Hello, So I have a Micro850 PLC with a 2080-MOT-HSC Plug-In module, and i'll be using this for an encoder. I think it was version 11 in CCW...
2,026
Hello: I use the 1769-HSC module in the compactlogix system, the cpu1769-L32E, now I use the 1769-hsc output, but i can't configuration and...
1,698
This is my first project using Allen Bradley's new(er) CCW... and I'm stuck. Here's the application: This is a small plastic extrusion machine...
5,070
Hy guys, I have a problem can you help me ? Well .. i have an CompactLogix L45 processor and a HSC module but i don't know how tu use de Z input...
2,159
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
141
