AB Micro 820 re-connecting
B777
Feb 2017
Sydney
Hi All, I'm trying without luck to reconnect to an AB Micro 820 I have recently downloaded a project to. Controller was new out of the box and i was able to see it/download via AB_ETHIP without having to manually assign IP.
After download it asked to save Ethernet settings and i haven't been able to see it via Linx since. I have tried the manual IP in the ranges 169.254 and 192.168 (controller IP setting via offline project) with no luck.
Anyone ever had anything like this before? PC OS is Windows 8. Thanks
Couple things....
1) When it fails the first time, click retry, this will open a new RSLinx and it will show your active nodes... not sure why but I have to do this a lot
2) Check your settings of the program you downloaded... if you had IP set to static or allowing the router to set the IP, either way RSLinks should find the node if its on the same subnet also make sure you are using your landline and not wireless as it may have a different IP setting
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
288
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
359
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
962
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
476
