AB Micro850 Modbus TCP and Ethernet/Ip
laj
Oct 2021
Perth
Hi all
IÂ’m working on a problem in which I have to read sensor data from a data acquisition module in the field that only communicates using Modbus TCP.
I need the data on a AB controllogix PLC for processing.
On site I have a spare AB Micro850 with Modbus tcp compatibility.
IÂ’m just wondering if the Micro850 has the capability to receive the sensor data through Modbus AND have the tags readable by the Controllogix PLC by the MSG instruction (read) simultaneously.
Basically can the unit perform both EthernetIP tasks and Modbus TCP tasks through the one Ethernet port or will I run into issues?
Any insight would be great.
You can read Modbus TCP data directly from ControlLogix using Modbus TCP Add-On Instructions available in the Sample Code Library.
Thanks got this hooked up and running and it works great. Thank you for taking the time to reply.
Hello, I apologies in advance if a solution for my problem is posted already but I searched the web and this site and did not find any answers...
2,295
Hello, This is my first exposure to CCW Micro8xx family. Someone will write to my existing micro850. Modbus TCP is turned on and I created a...
178
Hello. I want to use micro850 to read and write registers from 120 modbus tcp devices. I want to know if anyone that implemented such a solution...
483
Hello All, I am posting this in hopes of getting a little help as I am very new to Modbus. I need to control the speed of a compressor VFD with...
1,333
Hi, Iam Working in a project where Micro850 and Epson ROBOT is there, I need to read and write bits to and from ROBOT. Iam Using TCP/IP and...
1,268
